Accesează
contul existent
Cum efectuez setarile MMS?
  1. Poti efectua manual setarile MMS:
  2.
  3. Press the central key, then select [Messages] > [Settings] > [Multimedia messages] > [Multimedia message profiles].
  4. Press [Options] > [Add new connection].
  5. Enter the following information:
    • Profile name: Orange MMS
    • Home URL: http://wap.mms.orange.ro:8002
    • Proxy: Check
    • IP address: 62.217.247.252
    • Port: 8799
    • Linger time (sec): 90
    • DNS: Uncheck
    • Bearer: GPRS
    • In [Advanced settings]:
    • APN: mms
    • Login ID:
    • Password:
  6. Press [Save] twice.
  7. In [Multimedia message profile] select the saved profile: Orange MMS and press [Options] > [Activate].
The new settings saved and activated.
Raspuns din: 13-01-2012
Voturi:
